LBZ race tune
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
says table 60 not found in B1120 "engine overtemp torque limiting" when I ran the script. :confused:
1,696
TN
Chris, open your file that your going to run the script on. Then go to Edit --->Configure Display Units ---> then select "All", then "Metric", then ok. Now run the script and it should RUN.
But, I just tried this and I couldn't get the changes to apply.. :confused:
13,765
834
Here's a version of the tune with OS 6128.
  • Race tune 8-25 265s 3100_0001 OS 6128.tun
13,765
834
Tune pulls hard, but a lot of timing rattle around 2500 RPMs.
I'm trying to work it out but no luck. :confused:
At approximately what throttle position? It's been a while since I've run the tune, but I don't remember ever having any excessive timing rattle on my truck.
edit: It is set to drop to 1 injection pulse at 2400 RPM (no pilot), maybe that's what you're hearing?
1,696
TN
Full Throttle I get it, I didn't really try it out at 1/2 or 3/4 throttle; The rattle is pretty loud IMO, like a old Powerstroke.
13,765
834
Can you post a log with RPM, injection quantity, pulse, rail pressure, and timing? The timing really isn't that aggressive in this tune. I'm wondering if there is a multiplier that is raising your timing significantly higher than the desired tables are calling for. I've had problems with some tunes in the past that were adding more timing than I wanted, and I started pasting my timing tables into the max timing tables to fix it. I made this tune before I started doing that though. I'll do that and post the tune.
Dec 2, 2006
1,696
TN
I'll make a run in the morning with it and see if I can get some logging done. I'm a EFI live dummy, but I can log :D.
Thanks for you help Josh! I'll really like this tune without the rattle.
Whats the approx power you think?
13,765
834
Try this.
  • Race tune 8-25 265s 3100_0001 OS 6128_0000.tun
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
I got this first time I ran it from a 40 punch, approx 80-90% throttle= DTC Information
Code: P0801
Modules:
Description: Reverse Inhibit Control Circuit Malfunction
13,765
834
Transmission limp won't limit it to 2k. Was it stuck in a gear?
