LBZ odd problem...
Awenta
4,090
CT
I'd try turning them off first before swapping them out
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Just for grins, I would check all of the ground wires... I fought a intermittent fuel knock for over a year. Turns out a ground wire had worked loose at the right front of the engine:eek: I was super pissed it was something so simple but grateful to have finally found the issue. My point is to keep it simple, good luck.
I checked those first :/I checked both sides of the block as well as the driver side head. Did I miss any other grounds?
quinton
1,883
Granbury Tx.
You check the cam reluctor wheel? I would start by checking reluctor wheel cam, then pull valve covers and check out pushrods, rocker arms and valves. I had a lmm that o just installed twin turbos on and drove fine for a day parked it got it in the next day and looked like that video. Ended up being a pushrod broke off where the rocker sits in the cup. Had good compression on all cylinders to.
Cknight199
Aug 23, 2012
1,827
I was going to pull my injectors and have them tested, but thinking I'll save the change and check the valve train before doing that. Do I need to pull the lower covers or will the top covers give me enough of a view to check everything?
quinton
1,883
Granbury Tx.
I've always pulled both but you should be able to see the pushrods, not sure if you will be able to remove rockers though. Someone else may chime in that has done it.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Reuse the lower valve cover gasket it will be fine. And the only times I've had that same issues like i said was running incorrect timing when pulling pilot at every rpm. And once accidently ran like 36 degrees timing at like 2000 rpm
Cknight199
Aug 23, 2012
1,827
I can send you the logs if you would like but they look fine IMO. It wouldn't hurt though..
quinton
1,883
Granbury Tx.
His timing and pulse climb together almost. I don't remember his exact max pulse I saw but it was say 2600us 25-26* at 4k rpm. Everything in the log came up smooth.
Cknight199
Aug 23, 2012
1,827
Yep that sounds about right.
There is literally no timing rattle when this is happening either, if I floor it from 1800 rpm, it'll smoke like a train for the entire time until it shifts again, but surprisingly only a little rattle at certain parts. Much less rattle than what it used to sound like
