LBZ odd problem...
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Logs all checked out fine :/ huge thanks to Quinton for looking at them. I'm going to tear out the y bridge as well as the turbo and housing and go from there.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Which boost did you log? Map or boost dma2? And I can't remember if that's a iat temp sensor or a boost sensor on the y bridge... But that's a very delicate wire
Cknight199
Aug 23, 2012
1,827
Map, it's an IAT2 sensor, the truck has had that broken for years, but I replaced it just to double check and didn't change anything
Cknight199
Aug 23, 2012
1,827
So it's not in the tune? Not a crazy amount of timing for pulse or rpm
Nope, literally almost no timing rattle even though it smokes so bad. It was the same tune before/after the swap, even flashed in a stock tune and it does the same.
Just did a compression test and all cylinders are within 290-300 psi.
Cknight199
Aug 23, 2012
1,827
Tomorrow I am going to go through the engine harness. Took the turbo off today again just to triple check that nothing was off...
Could injectors be a reason its happening?
Today I noticed something weird. So I already knew it was backfiring, but I can go in more detail now. It revs up to 4k fine, but when I let off the throttle it acts fine as well. Its only when I get back into the throttle above 3200 rpm's that it will POP and white/black smoke will come out of my tailpipe. I have to give it about 50% throttle before it will respond and then it will POP and rapidly get back into the throttle.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
I don't think i would waste time checking the engine harness if all sensor inputs are ok according to logs. I would be looking at taking it to a shop that was very good with duramax diagnostics and had all the right tools and info to figure it out.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Just for grins, I would check all of the ground wires... I fought a intermittent fuel knock for over a year. Turns out a ground wire had worked loose at the right front of the engine:eek: I was super pissed it was something so simple but grateful to have finally found the issue. My point is to keep it simple, good luck.
