LBZ: Do LLY injectors fit LBZ heads?
slowlmm
Mar 2, 2008
2,582
46
so cal
I wana say its right around the 7inch mark or right under the B but its hard to tell from the pic. I allmost wonder now if it was LMM injector they sent us I wonder if those have the lip on them i will have to take a pic and post :confused:
Trippin
SoCal Diesel
Aug 10, 2006
663
LBZ injectors will not fit into LLY heads. There is a .010 difference in diameter of the injector bore at the valve cover side of the head.
LLY injectors will fit into LBZ heads. There will just be less press on the rubber O-ring on the OD of the body.
I have a couple of customers that have already done this swap.
The GM prints come in handy.
Trippin
SoCal Diesel
Aug 10, 2006
663
Yup, can't physically swap them.
Makes me worry why GM did that. I wonder if there is another difference. Often you make parts mechanically impossible to swap if there is a danger to the engine.
I think they shortened the glow plugs to make it eaiser to remove without moving the steering shaft.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
In case there is an electrical incompatibility.
Lots of hotrodders need to know what can be swapped so they can save money.
In my case I have an LBZ engine I put into my LLY.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
OK, I see now. There is a step in the dia of the LBZ body that doesn't occur on the LLY. I think it would fine to either turn down the body, or use a .840" dia reamer on the head to take out a little metal. McMaster PN 2777A913
ripmf666
15,123
14
47
Wentzville Mo
so I can run the lly injectors in my lbz if I needed to or found a set of ported ones cheaper then doing my lbz injectors, Am I taking this in right or wrong.
ripmf666
15,123
14
47
Wentzville Mo
na in his post the lbz would need turned down to fit a lly head the lly injector would be lose in the lbz head, the lly is .820 all the way the lbz is .820 then goes to .835
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
super old thread, but I have to ask...to make an LBZ/LMM reluctor wheel work with an LLY ECM, I know you have to grind a tooth off. But does it matter which side you grind it off of???
Theres the big gap in the teeth...if you are looking at it from the front, does it make a difference whether you grind the tooth off of the first tooth on the "left" side or the "right" side of the big gap???
thanks
Ben
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
thanks
Ben
Here you go Ben
http://www.duramaxdiesels.com/forum/showthread.php?t=738&highlight=reluctor
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
If you want to use LLY injectors in LBZ heads, they fit fine. Go to Harbor Freight and get the Metric O-ring assortment, and pick an O-ring that will keep the injector centered in the bore.
dirtboy726
victim of diesel hotrodery
Mar 13, 2010
104
nova scotia, canada
ok i have read through this thread and i took in and worked the info through my head.
my buddy might be parting out his lly with 60 over injectors in it...
i can buy them and put then in my lbz with no physical changes other than an o ring to center it in the bore?
thanks
just trying to understand completely.
