Yes, physically. I just put an LLY injector into an LBZ head. Now I need to check voltages.
Glowplugs ARE NOT interchangeable, not even close. I don't know if you can hook up LBZ glowplugs to LLY wiring.
The water pump has a larger diameter exit, and different water line routing, but you can stretch the LLY hose over the top.
The reluctor wheel on the camshaft has a different number of teeth. The LBZ has one more. So you can grind one tooth off and use it. We did this on Casper and it worked.
I'm checking on this stuff so we can tell what you have to change on an LBZ head or engine to drop into an LLY. Glowplug and injector voltage are the only unknowns I haven't personally verified.
