LBZ 73 Nova
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
looks great Russ.
Thanks Ken! Just ordered the rest of my safety equipment last night, should be here mid week. Getting the car together the rest of the way, and will be ready. Still need to mount the engine diaper plus fab up a belly pan. Not sure if I will have enough time to hit NHRDA Az this weekend, it will be close.
IdahoRob
Jun 5, 2007
1,151
Um, Russ.....that car is going to be a handful (meant in a good way). Man, you are going to have some fun. :)
What was Rob's opinion of how it ran once he hit it a couple times?
Tom, the car really responded to some tuning. The biggest goal was to have the low and mid range cleaned up and seemless TPS. Easy to make top end HP, but with this large triple set-up and driveline configuration with trans brake, it took a bit of work. This is the first time I've spent any amount of time working on the tuning for the Nova.
It now spools very fast, on or off, the trans brake with very little smoke. The throttle sensitivity was also worked on so it could be staged consistently. I'm very happy with the results.
The base tune went over 1000RWHP as Russ mentioned and that was on a total of 1500us of fuel and only 40 lbs of boost. We couldn't load the dyno as any load applied to help the turbos and it would shred the slicks.
I believe it will be a very nice combo on this base tune and should be easy to stage, spool, and launch.
rfletes79
649
174
Galt, Ca 95632
Rob, you are the man!!! Glad you and Russ were able to get it dialed in. Car looks like it's running amazing. Can't wait to see it make some laps at the track.
1,941
Thanks Rob. :) Only 40lbs of boost and 1500us? Cripes. I'll say it again, that car is going to be a handful.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Made a few test launches down here at sea level before putting it in the shop. Throttle response is amazing (gasser like), and absolutly zero smoke. On the brake I was able to lite the turbos at a crazy low 2k rpm's. She comes alive quick and finding second gear while sideways was interesting to say the least. The car is up on the rack getting the wider rear diff & new tires installed, plus fixing a couple minor leaks at V-bands on the hot side. All my safety equipment showed up today, can't wait to hit the track and get the suspension dialed in. :woott:
56taskforce
1,081
56
:happy2: for a lack of words to show how excited I am for you Russ. The Camaro is bad ass but the Nova is, well the big brother...:thumb:
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Current situation, as some may have herd.
Big tune was.. well..., a big tune! Pulled the front tires up at around 100' 500' and 1000' while giving Rob in the next lane a show. Something let go when it came down the last time and sent me into the wall, then onto and up over it the second hit.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Some one was trying to be a graffiti artist on the windshield in this picture, good to hear you're OK........:thumb:
1,941
Im sorry I foreshadowed that, Russ. Damn glad you are ok.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
This is my biggest fear in doing this crap. So much time and money down the drain. Do you plan on rebuilding?
Not sure how the under side looks yet, that will be the deciding factor. The front clip is not an issue. I took out 50-60' of K rail riding right across the top of it, plus the 15' from the initial hit.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
It's a risk we take buddy, the four link was not set correctly for that power level, but was good on the smaller tunes.
I don't know anything at all about 4 links. But I would love to hear a more detailed explanation of what you mean here.....
I'm glad to hear your ok. Looks like a gnarly wreck.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
I'm not a 4link wiz either, but if I had to guess they needed dropped in the front to get more push instead of lift.
Sorry to see the car in that condition, but that's all replaceable. Good luck on your recovery Russ :thumb:
5,911
I'd assume they needed more anti squat and change instant center a bit.
Damn Russ, that sucks to see but at the same time, all that hard work to keep the driver safe did its job and well.
