LB7: Lb7 turbo leaking coolant
Justalb7
Mar 14, 2016
I have a 2004 lb7 and the turbo is leaking coolant and running out tailpipe and the water pump started to leak bad anyone have any idea what is going on?
ChrisPerry
Apr 4, 2016
209
Ventura, CA
If wp is original, I'd say just it's time. If newer wp maybe corrosion from neglected coolant/electrical short. If running poorly maybe blown head gasket causing excessive pressure and forcing coolant out anywhere it can.
Now, coolant out exhaust, are you sure it's from the turbo? Does your truck have egr? Possibly egr cooler. Blown head gasket can cause coolant out exhaust too.
Whats the history of this truck? Mileage? Modified? New to you? Used for heavy towing?
Fill out your signature under your user profile so everyone knows exactly what you are working on.
1,868
Moved into LB7 section of Hard Parts.
Please, in the future, dont post the same question in multiple areas.
You have multiple problems going on. If the waterpump is leaking, address that separately.
For the coolant out the tailpipe, I would be checking for blown headgaskets first.
