LB7: Lb7 turbo carnage
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
Wow, did you monitor exhaust pressure? I'd be happy with a safe 30-32psi of boost. Maybe it will help with my egt while towing. With out a regear these tires put my sweet spot up to 80mph. At 70 mph I'm at a constant 1200* with a 20k load.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
ironmax
Jul 7, 2010
502
27
Col. Ohio
It's official I need to go fishing for the exhaust turbine in the exhaust pipe.
ironmax
Jul 7, 2010
502
27
Col. Ohio
I've got property across from iron pony I run my construction and roll off dumpster business out of, and property out in london where we run used semis and equipment out of. We run older iron but it's solid and clean.
ironmax
Jul 7, 2010
502
27
Col. Ohio
Most of the exhaust bolts broke, but it's out and I'm beat
lutzjk913
1,681
168
groveport, ohio
Yup. I know exactly where your at.
Collision 1 is a good customer of mine.
I live down in canal/ lithopolis area
ironmax
Jul 7, 2010
502
27
Col. Ohio
We're not the red cans next to collision 1, we have the black cans 2 doors south. I live north east of deleware though. I've been doing a lot of work around Groveport this year. What do you do?
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
Sorry to see your bad luck but glad we can get you taken care of. This 2.5IHI Stg2 of mine is a 63.5mm Billet wheel(my personal design) and is good up to 670hp with no sacrifice of lowend just more mid and top end power with it. Make the truck a lot of fun to drive.:thumb:
How well do these work on heavy Kodiaks?
lutzjk913
1,681
168
groveport, ohio
Ahhh. Ok
Nice where at down this way?
I work at Ricart selling wholesale parts.
ironmax
Jul 7, 2010
502
27
Col. Ohio
This came yesterday, getting er installed Waiting on some exhaust bolts and gaskets I was expecting to be here. Still have to clean the intercooler out. Maybe by wed I'll be finishing up, but probably won't finish till next weekend with how busy work is right now.
ironmax
Jul 7, 2010
502
27
Col. Ohio
Finally got back around to this project this weekend and got her back on the road!!! I can't tell a difference between the two. The one that popped was a ported and polished ihi with the batmo wheel. The new one is not ported with the bigger wheel by danville, and a ppe boost valve. I'm on lbz regulator stock fueling with 20%nozzles, new turbo makes 22-23 lbs bounces a little ,old turbo did 25. Probably need to test for leaks but I know I've got the fuel for 27-28 psi. I can get to 1400 egt pretty easy on flat road. Pressure is being measured at the y bridge with a autometer gauge . I was under the impression the boost valve would get me to 26-27 psi. What else could be happening? Weak wastegate?
Sent from my SM-J337A using Tapatalk
ironmax
Jul 7, 2010
502
27
Col. Ohio
First heavy tow with the new turbo, got a say it keeps the egts in check. Usually would hang at 1200-1300 with the last one. 1100° is the average with the new one.
ironmax
Jul 7, 2010
502
27
Col. Ohio
Any ideas what causes this? Putting this thing back together after number 7 injector took a crap and found this. I'm pretty sure this truck hates me now, cause it doesn't get alot of attention anymore. Boots are all good on the intake. Only thing I can think of is I left something in something when I put it back together in a hurry
Sent from my SM-J260A using Tapatalk
