Does the dash show correct rpm? I googled the 0374 and found that's a "high resolution" crank/ signal. You would have removed a wire tied to measure rpm for 1 of the 3 thresholds for the allilocker to lock. You probably messed up the engine speed sensor wire. Iirc it's a white wire
Only wire that was cut/spliced into was a brown wire, pin 29 on the red connector to the TCM... then the blue and white wires (from the allilocker) were tied into that wire... white on the allilocker was tied to the tcm side and blue from the allilocker was tied to the harness side.
Other than that it was ground to chassis and 12v to ignition.
So the brown pin 29 wire could cause this? I don't have a schematic off hand but that's the only wire from the trucks harness that was cut/spliced into.
So the brown wire must be for the engine rpm front what you're telling me?
When we put the transmission back in two of the speed sensor clips (male end) had broken tabs. Would a bad speed sensor on the trans be a possible culprit as well? Trans has been out 3 times that I know of.
Other than that truck has a DSP5 switch that stopped working after the engine was built. One of the two wires for that could be broken but then it would just be stuck in the no 1 position tune which should be the big tune. They just haven't had time to replace the dsp5 because the trans was out again because of fried c3's.
