Does everybody think that EGT represents cylinder or piston surface temperatures?
EGT is not a predictor of piston conditions, it is a thermodynamic derivative of evolved combustion. Actual temps in the cylinder are 3x higher, over 3000 F, though constantly changing throughout the stroke.
What happens between TDC and the turbine is a long trip. If you really want to understand what is happening to pistons, you have to measure CP. From that you can extrapolate with compression formulas to calculate cylinder gas temperature. CP spikes and temp spikes in the cylinder do go hand in hand...but that is a thermodynamic correlation, pressure=heat. 5 degrees of timing difference is everything in this situation, and will dyno the same, yet the more advanced condition will have a great deal more mechanical and thermal stress. The best way to damage cylinders, is to try to absolutely max out timing. And if you did that on a cool day, low IAT's, no heat soak...then take the same tune out in the summer, do a few 1/4 mile passes, now timing is way over-advanced, and CP is getting way out of control. This condition won't really show up on an EGT gauge either. EGT is not going to tell you necessarily that what is happening to the piston is toxic.
As I have stated before, ECT and IAT timing retard are very important.
But I could be wrong.
