How do you know if it pops?
Fuel rail pressure will fall off, and most likely will not come back up untill you allow the truck to come back to an idle, or maybe even sut it off and restart it. Thats what mine has done when it poped open anyways.
Ok Im bringing this thread back again. I am having a problem with my truck not holding rail pressure. I am commanding over 25000psi and it is almost cut in half at WOT. but when I let off it jumps up to 26000psi and comes down fine.
Any suggestions? Where is the FRPRV located?
Just because you command it, doesn't mean you can hold it. Do an injector return rate test(bottle test), and I bet you will find it is bleeding off to much fuel.
In the fuel junction box on the drivers side rail. Its normal to see a spike in rail
psi when you let off the throttle quickly. I'm going to plug mine as well, maybe
it will solve my rail psi issue.
Can any of these lead to hard start issues? Weather the truck is warm or cold when starting?
It's not uncommon for the P0093 to be a false code on an 01. It is a known issue with 01's to pop it for no reason. Make sure it has the latest factory flash from GM in it 1st as early operating systems had problems. Quite a few of us have upgraded to an 02 operating system for several reasons, and this being 1 of them.So this seems to be the go to thread on the lb7. Have an 01 that intermittently decides to pop an 0093 cel, whether at load or just a leisure cruise down the road.
Truck has a bully dog on it which was run on 2 most of it's life of 98k.
Bully is set back to stock and been that way for a month now, at first I was leaning fprv, bottle test was not done, trying to get the owner to perform one. Besides the bottle test and me nor having a tech 2 to check desired vers actual is there any other things to check without 2K in equipment
Sent from my SM-G925V using Tapatalk
