Yesterday I had a first time occurance of coolant spilling from my overflow tank. My truck was basically covered on one side with coolant. So once I got home I took a real good look and determined it was coming out of the overflow as the hose was wet. Then I figured... Ah! It must be my pressure cap and/or thermostat acting up. Only logical thing... Then I read on forums that it can also be my head gasket and/or injector cups. So I let the truck sit for three hours and when I came out to check the upper rad hose it was hard. I opened the coolant reservoir and fluid was spilling out still. Now I don't quite know what to think... My truck is unmodified bone stock with 200,000kms. Need help! How can I determine if I am really screwed and what could I try. I am thinking about stopping by the stealership to get a new cap. Should I also change the thermostat or do you guys think that it's for sure the head gasket and/or injector cups.
Driving it this morning didn't seem to cause further spillage. It drives totally normal and the oil seems just as clean as when I put it in.
Thanks in advance!
Thanks in advance!
