Lb7 build
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Katie, the world really can't handle a truck/girl combo like this...for the good of mankind, spare the unworthy and sell it to an ugly f'er like me :D
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Thinking I'd like a new converter but unsure which I'm gonna go with.
Mines getting a ATS 5 Star 2800-3K stall billet stator, and some other billet parts. Hope it spools better then the 1057 that's been in there.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Don't forget about Goerend's as well.
That's what's in it now I don't like it
Hahahahaha thanks I thought about selling
I had an ate converter before I liked it
If Duramax tuner doesn't have a idea on what convertor you need I would not let them touch it..
I haven't asked them yet haven't really talked to them since it broke, they know I don't like the Goerend even tho it's a good pair.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
I was waiting patiently like a little kid at Christmas to see a girl behind the wheel... And then noooooooo.
Hahahaha nah. He jumped in to move it quick I figured I'd grab a quick video lol.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
https://vimeo.com/145088438
This however is a hilarious attempt of a burnout the day I picked it up at Jason's.
They told me I wouldn't do a burnout jumped in and attempted one before even driving the truck. As you can tell I was a little overwhelmed with all that power. It scared the shit out of me lol
1,936
Goerend does make different converters, ya know. Might pay dividends to call them first, outline your concerns and ask if they have a solution.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
I spoke with Eric thankfully he's offered to warranty the trans and I'm thinking the stall just needed adjusted it seems a little tight to me. I'm gonna stick it out with the goerend make some adjustments and hope it makes a difference
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
You may have already said, but what stall is in it now?
If you're planning on switching converters, then get with suncoast and don't look back.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
I honestly don't remember where the stall is set I know that it's tight and now there's something wrong with the trans or converter sounds/feels like it gets hung up.
I originally wanted a suncoast but was talked out of it lol
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Goerend Converters are just as good as suncoast. Lifetime Warranty and 1st restall is free. My next converter will be from Dave.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
How does someone talk you out of suncoast?:confused:
It was more or less I asked Eric what would be a better match. He suggested goerend so that's what I went with.
I did not know that.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Really debating on selling the truck
40k obo
I'll have trans fixed by Merchant
here is all the info on the truck
Any questions please let me know
engine built by Wehrli a Custom Fab
Tuned by Duramax Tuner
Specs;
Socal Girdle Kit
Carrillo Rods
Fingers Oval Cast mahle Pistons 16.5:1 Ratio, .020 with valve reliefs
New GM Oil Pump
New GM Oil Cooler
Comp cams Valve springs and Retainers
Ported Heads, 5 angle Valve Job, New Seals and Guides
Screw In Injector Cups
New Exergy 150% injectors
Air dog 4G
DRP Fuel Sump
Socal Billet Injector Hold Downs
Socal 9100 AF Cam
ARP Headstuds
ARP Rocker arm bolt
SoCal Damper
Suncoast Billet Flexplate
ARP flexplate Bolt Kit
PPE manifolds
PPE Intercooler
WCFAB 2" stainless Up pipes
Merchant Motor Mounts
Dual CP3's
pushrods
WCFAB compound kit
(S591 over Duramax Tuner stealth 64.5)
Oldskoolfab Carbon Fiber Stack
Can provide full engine build sheet
Gauges;
All Isspro gauges Black face white backlight
Pyro, 2 boost gauges, fuel rail pressure and I have a brand new trans temp gauge.
Also a digital DSP5 gauge from BT DieselWorks
Trans;
Built by Merchant Automotive
Suncoast GMAX5 clutches
Billet Input shaft
Billet Output shaft
Billet Flexplate
Billet c2 hub
DRPA Upgraded tranlines
Etc...can provide full trans build sheet
Suspension/Front end
Lowered 3" (beltech drop shackles)
Rancho 9000 shocks
Merchant Tie rod sleeves
PPE straight center link
ECSB SLT
Engine has less than 2k miles
Truck has 215k (roughly)
tan leather interior no rips
Or tears normal wear and tear on drivers seat back seat is pretty much brand new.
(Don't have the bolts for the seat tho lost them when I moved from
OH)
Black Carpet
Bose sound system
Indash radio
Spray in Bed Liner
Truck was repainted 2years ago
No rust/clean underneath
I have an extra front valance the one of the truck has some stone chips.
I have an extra hydro dipped GMC emblem
(The one in the truck is white and silver the extra is black and white)
2 sets of wheels and tires
20x10 BMF Rehabs on the truck with 305/50 toyo proxy (less than 700miles on tires
16x10 with et streets brand new mounted on rims but zero miles on them.
I'm sure I'm forgetting some stuff feel free to ask for any photos or information on the truck.
