Larger compressor pumps (garage)
Jan 28, 2015
961
Ohio
I bet it leaks oil from somewhere. Do yourself a favor a check the line that runs up the right side. The eye glass and the black plastic piece that in on the back side. There is a square cut out in the cage for it. Mine did and so did the one at a buddy's shop. Both 80 gal 2 stage but assembled at the same place!
motoking_1990
1,957
5
Terre Haute, IN
Picked this up just barely. Price was right and it should suit my needs just fine. Rated at 14.1cfm@90psi.
Looks like mine
Digmax
289
We have one similar to this, think its 80 gallon though. It has a 2475 model pump on it been very pleased with it
Sent from my C811 4G using Tapatalk
motoking_1990
1,957
5
Terre Haute, IN
I'm going to have to change something with mine I'm not getting enough pressure at the hose. Maybe I'm just used to the air pressure at work idk.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Get yourself a set of Milton "V" style quick connects from the tank to the tool. They are night and day difference from standard connectors. Also if you're running through a regulator make sure the regulator can handle the cfm you are needing to run your tool.
