kryptonite race centerlink with heims
c5fourj
Occasionally moving quick
Dec 20, 2014
307
3
Brighton, CO
So if its just a non-tapered 7/8 hole, then it would work in the kryptonite center link if it was to be drilled out?
N2BRK
2,054
371
Ok, good info! So the PPE bolt stays fixed or does it just pivot to a lesser amount than the other pitman arms?
5,828
All pitman/idler arms should have 0 movement in any direction other than just spinning inside the cup. PPEs setup won't allow any movement other than letting the bolt spin unless something is very damaged
N2BRK
2,054
371
interesting. I can tell you first hand that Rare's will move in every direction with no resistance.
5,828
interesting. i would not want to use it then.... if the Idler is taking ALL the load, it should be double sheared, no if/ands/or/buts about it, doesnt matter what idler arm you put on it either. a person should also be running a super steer or kryponite idler arm support as well with a welded/bolted in brace. that is an extreme amount of load to put on one steering part.
N2BRK
2,054
371
and maybe that's why my Ultimate Idler ultimately failed, lol. I have the Rare pitman! It's also interesting that Rare tried to buy my Ultimate idler from me and trade me their idler arm, I passed. Maybe I need to get it the heck outta there :(
