Just put a tuner on my truck
SlowSilverado02
Feb 3, 2015
35
Awenta
4,090
CT
Lol yeah not on that one. Need the insight monitor.
N2BRK
2,059
391
My buddy started off with a Quad to delete the DPF and the Edge Juice with Attitude for tuning. The Edge was so fussy that it would sometimes no-start until he unplugged and replugged, sacrificed a chicken, etc. At the time, I was on a Banks 6-gun with SL. We sold all of our tuners and bought an EFI Live V2 together! Our other buddy had stacked a Banks 6 gun with a Superchips tuner, lol. He bought a V2 just before we did, lol.
N2BRK
2,059
391
BTW - I use an Edge Evolution on setting 0 as a monitor on my truck :)
56taskforce
1,081
56
I was told by a number of reliable sources that it is not a good idea that 0 is not really stock it is optimized stock making it it unclear what is really happening within the system. I am old school and like guages however the guages I want are spendy and I have hit a temporary financial road block so they are out of the budget for now. In bad need of monitoring engine vitals now I bit the bullet and bought an Edge Insight CS and EGT prob, I will mount it in billet overhead mount that the Attitude from my old Edge Juice was in. The screen may be small and I am blind as a bat but it monitors everything I need, has audible alerts and won't break the bank.:thumb:
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
fill out your sig and how many miles. I did a LB7 awhile back that had rail pressure issues and since rail pressure was very low no change could be felt after tuning. you might have an issue going on like that too.
SlowSilverado02
Feb 3, 2015
35
My dummy engine temp gauge is WAY off, when it reads like 180 my Attitude monitor says between 130 and 145. I had to break out the cold weather bra to get it to 174 degrees for the tuner to actually work. It has a built in safety that doesn't let any tune work till it hit at least 160 degrees. Then it only gives you 50% of the tune you select until the engine temp hits 174 degrees, at 174 it will now give you 100% of the tunes. So it does work, it just took me a bit to get it to temp.
02 four door dually with 142000 miles, Bills intake, 5" MBRP from down pipe back (no muffler) and Edge Juice with Attitude
SlowSilverado02
Feb 3, 2015
35
The Evolution doesn't do anything to my tune, but as I recall the Juice w/Att is known to add timing even on setting 0.
Ahh crap, so sell it and sink more money into it.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
That is by far one of the worst tuners out there. I used to have one on my truck, wide open runs it would defuel terribly on shifts even with defuel off it would cut out like no other. Once in a while truck just woukd straight up not build boost so id have to restart the tuner to fix it. And no you cant use just the monitor part, it has to communicate with the juice module. I got efi live from tony at ridge runner diesel "moonshine" and its a night and day difference. Do the research theres many good efi live tuners out there. And some not so good ones.
SlowSilverado02
Feb 3, 2015
35
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Thought I posted this earlier but I don't see it in the thread. I wonder with your engine temps the way they are if you have a bad thermostat/s? You shouldn't have any problem getting your truck up to temp unless you live in an extremely cold climate.
SlowSilverado02
Feb 3, 2015
35
It's been anywhere from -0 to 50. I liven in the communist republic of NJ. What do you think is proper, what the attitude is reading or dummy gauge?
SlowSilverado02
Feb 3, 2015
35
Where in NJ???:thumb:
I really don't like to say, but Moorestown. Don't hold it against me, I'm originally from Pittsburgh PA.
