Fuel route is from FICM to filter to CP3. I did hook it up backwards initially thinking that the FICM should get clean fuel. After using some air to blow into what thought was the supply line and getting no-where, I realized that I didn't have a blockage, I had the filter assembly backwards.. When turned around right, the truck stayed and ran for about 40 seconds before I turned it off. It hasn't run since.
I have since checked the lines, reclaimed everything, added a lift pump, and verified return flow from the return line after I crank. Actual fuel rail pressure never rises above 1.8MPa, not nearly enough to get it to start.
I wonder if I have a jammed fuel pressure regulator, or I got debris into the CO3 and trashed it. I've ordered some injector caps and I will build a fuel return flow test rig to see if I have any bad injectors after the engine sat for 7 years... I'll check the fuel pressure relief valve too to make sure it isn't bleeding off the pressure.
Any thoughts and suggestions welcome!
