The truck was very close, and then it went backwards, spent the last month chasing mistakes and shortcuts done by the previous owner. Here's a picture of the wires that we pulled out, keep in mind it has all the same electronics as it did before, fans, water pump, locker and lift pump
^ all the wires removed.
wires on left, new harness on the right. Hard to believe it didnt burn, pictures don't do it justice.
The duel fueler wasn't even close to being aligned, it was running with half the belt on, 2 pinched off fuel lines, was set so low it would cause the truck to drain the rails. No MAF, bolt missing from the bellhousing, every hose that was added, fuel or coolant looked like a 2 year old had cut them, alot of them didn't have a hose clamp. Oil return for the valley charger wasn't done up, sprayed oil every where. I know I am forgetting alot. I just want to thank Motorhead Garage ( Cam and Kirk ) for all the hard work they have been throwing into the truck, Can finally see the light at the end tunnel.
