A medium duty built truck uses a standalone abs system iirc and I don't think its on the comm bus.
No...thats incorrect.
Also you could just buy an ipc for a non abs truck.
See the first response above...
Guys. First of all, this is a GMT-900 that Josh is working on. NO CLASS 2 DATABUS. Only GMLAN. GMT560 kodiak/topkick is Class 2. So nothing out of a -560 will work in a -900. And second of all, all -560 trucks have ABS...so finding some "non-ABS calibration" is a fallacy because it doesnt exist. And third of all, -560 ABS systems are not "standalone", they communicate with the cluster etc..
And forthly, the ABS, SIR (airbag), and other "safety critical modules" must send a keep-alive "everything is ok, Im checking in" message to the IPC every second. If the IPC doesnt get this constant "system OK" message every second, it DEFAULTS to a "failure mode" that turns the warning lights and DIC messages on.
Problem with the ABS ---> ABS module requests warning light illum.
ABS module unplugged/missing ---> IPC sees no ABS module, and turns on warning illum itself
Ben
