You could go with some aftermarket tierods and an aftermarket centerlink. SAS comes with its own problems as well.That solid axle swap is looking better and better everyday.
This is also a valid point. I have washers on my t-bolts so that after i let them down I can just snug them back up to the washers and know they are back in the right spot. Helps when you are adjusting them often.You could have simply not put your torsion bar adjustments back to where you had them set before.
Ive launched my truck many many times. Yet to have to go back and get an alignment.
If you got good steering parts and everything is sinched down tight, it shouldnt be an issue if you put the torsion bars back correctly. 1/2 turn off can make your truck pull one side or the other
That's what had me thinking something is bent. I have the t-bars where I wanted them when I got the alignment and sleeves. I don't have to adjust them up and down after the track.
