I did have one ppe die but the replaced it cause there was somthing wrong from the factory...they make a helluva little pump
you can T the line out and T the line in and run a 12 or 15 psi check valve between them so the pump can still cycle fuel at idle and not build pressure...i never found it to be a problem
