Injectors needed soon in lb7. What to get or do?
SofaKing
Jul 20, 2015
15
Wisconsin
This is the second set I know of going into the truck. Last set was 9/23/13 and the shop didn't put new injector lines or lift pump. So my turn. The injectors they put in where part number DT97729095R. Now do I get these rebuilt? Was thinking about having La Crosse Diesel Service http://www.lacrossediesel.com/ do the work. Anyone have any experiences with La Crosse Diesel Service?
Or should a I be look for something entirely different for injectors? what is everyone's experience with the multiple reman injector companies out there?
Definitely putting a lift pump in and new injector lines.
Awenta
4,090
^^x2
Don't try to save a couple bucks on shady remans. You'll just end up redoing them.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
X3 on Brent at Lincoln, I've bought several sets from him for my customers and is the only company I trust. Fast shipping also. You won't regret doing business with them.
Brent@LDS
651
Wisconsin
Check us out and we will get you taken care of with a quality Bosch injector! Looks like they put a set of D-Tech injectors in your truck based on the part number you gave. Where in Wisconsin are you located?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Cant the lb7 SAC injectors be used with stock tuning?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Man whats it take to get good info, i called merchant the other day to ask this same question. Customers truck needs injectors and i asked merchant if the new sac style injectors would be fine on stock tuning and the guy said yea lol
Awenta
4,090
Smallest SAC nozzles are about 45% over. That's way too big a difference.
Brent@LDS
651
Wisconsin
Let us know if we can help you out, we have very good prices on our injectors as well as customer service.
3,729
297
Well technically they would work, but not work right. It would probably idle fine, but you would be way over-fueling any time you got on the throttle, and most likely smoke up a storm driving around town. To run correctly, they would need a tune to get the MAF limits and timing adjusted to take advantage of the additional fuel, or even just dial the PW back to keep power stock if that's what you want.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ill be contacting LDS, i like the deluxe install kit though that merchant sells
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
The verdict seems to be split on wether the SAC type injectors will work in a stock truck with stock tuning or not.I know KENNEDY sells them and in his opinion they are OK to run on a stock tune in a stock truck, but tuning is reccomended for best results, and do not run a tuner if you have a stock trans and to go back to stock tuning if you swap em in.
Electro-02gold1ton
Super Dually
Nov 15, 2015
35
ABQ,NM
Sofa king are you still on stock exhaust manifolds? If so putting on some profab or PPE manifolds might help to extend injector life as well the stock driver side manifold is poorly designed, replacing those will help the truck with EGTs and make everything much happier in long run!
5,911
absolutely not....
where do guys come up with these "extend your injector life with....." ideas :confused:
