Injectors needed soon in lb7. What to get or do?
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Sofa king are you still on stock exhaust manifolds? If so putting on some profab or PPE manifolds might help to extend injector life as well the stock driver side manifold is poorly designed, replacing those will help the truck with EGTs and make everything much happier in long run!
what kind of research have you done to back this up or come to this conclusion?
SofaKing
Jul 20, 2015
15
Wisconsin
Brent@LDS besides the injectors, install kit and a lift pump is there anything I forgot? Would you keep the factory filter too or would you put a delete kit on?
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Some delete it some keep it. As long as it's keeping its seal I don't think it hurts to have a last stop filter incase something got by your lift pump filters. Just my opinion
Electro-02gold1ton
Super Dually
Nov 15, 2015
35
ABQ,NM
absolutely not....
where do guys come up with these "extend your injector life with....." ideas :confused:
Cylinders 4 and 6 cannot disperse heat as quick as the rest of the truck with the stock manifolds. You telling me that has no effect on the way those injectors perform? I thought that poor design was part of the reason why the LB7 was killing injectors so easily? I could be full of it but makes sense to me, heat is a killer less heat things live longer function better IMO.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Same exact manifolds were used until 2010, GM didn't change until 2011 for the lml. LB7 injectors had/have several issues, but an exhaust manifold is NOT one of them.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Swapping the drivers side manifold for a mostly stock truck might drop egts what 75 degrees at best. How is that gonna change anything? Most injector failures are either dribbling nozzles because some soot or debris hangs the needle in the vco nozzle open, or the ball seat erodes over time causing high return rates allowing the injector to open on it's own. How is either of those failures heat related. I've seen more failures at the back of the rail on 7 & 8(where any contaminants woyld settle out and get into an injector 1st), so there goes your 4 & 6 theory.
Brent@LDS
651
Wisconsin
I would recommend sticking with a CAT fuel filter setup in the factory location. Can't have to much filtration on the LB7.
