Was talking about what size just yesterday. I drilled them on a LLY some years ago with stock pump. No issues. 5/32 drill bit comes to mind, but don't take that as gospel. So long as you leave the spring and check ball alone, they only spray at above 27psi.
I can say the LML squirters are considerably lager than you could even drill out the older ones. So GM found it benificial to
Increase cooling of pistons for some reason.
Sent from my SAMSUNG-SM-G870A using Tapatalk
