He was running just under 60mph tops, and I figured 750-800hp range with that compound setup. However the failures all occurred getting on plane when the prop wasn't hooked up yet.
For example, the stroker pistons let go while testing a new prop that wouldn't hook up. It would cavitate bad and run up to about 4200r without nosing over and hooking up on plane. So load wise, it never saw much load then. But on the 4th try, she blew the side out of a piston at around 1400egt.
Then with the cast piston single turbo setup it had been running good, and was getting on plane again when a piston let go about the time it shifted into 4th gear. Saw egts hit 1400 he knew something was up..
If it had been on plane at wot, then I would say the loads were high. But these failures all happened with ecm estimated load under 50%.
Sent from my SAMSUNG-SM-G870A using Tapatalk
