Injector lines...
hipp11B
Apr 1, 2015
252
Georgia
This may be a stupid idea, but an idea none the less. I know gassers do it but have never seen it done on a diesel. Has anyone ever replaced there injector hard lines with braided line and AN fittings? Seems like a cool idea in theory and it would definitely look cool. In my mind the problems I see would be possible leaks more so than with a hard line and the fact that it would appear nobody has done it...probably a reason for that and I may look stupid for this idea but what the hell never know until you ask right? Haha so let's start a conversation on this, pros,cons, can it even be done? Idk.
Lbz, built trans, efi by Eisenhart diesel, Danville 68, full egr delete, mbrp down pipe, 5" mbrp to 7" stack, ppe guages, custom traction bars, airdog2 165, ppe fuel rail mods, s&b, age blade runner, Arp head studs..died March 2015
CaptPhil
1,012
Delaware
Are you talking about the supply and return lines or the actual eight injector lines? The injector lines can't be done, they have to hold 26k psi or more. Plenty of people have done the low pressure side in various soft lines.
hipp11B
Apr 1, 2015
252
Georgia
Yea I was talking the actual 8 injector lines, I figured it was something along those lines or someone would have done it before, to bad would definitely look pretty neat. Thanks for the input sir
jliddle
Jun 30, 2012
331
NC
Best way is to clean up all the hard return lines with AN stuff to a distribution block. Minimizes some of the line spaghetti for a clean look.
As mentioned the high pressure lines are there to stay.
PACougar
2,105
41
El Dorado Hills, Ca
I will say, there are semi flexible lines that exist and can handle the pressure. You'd have to do some research, but it's not out of the realm of possibility.
Awenta
4,090
CT
There is hose that can do it. There's several options for flexible hose that handles 30-40k psi. Even 60k.
But I don't think it would cleaner at all. You can't bend a flexible line 90* like you can a hard line. You might even need to go to opposite rails to avoid having a big loop on each line.
hipp11B
Apr 1, 2015
252
Georgia
Hmmm I'm going to do some digging and see if I can find it, I mean if I'm spending all this money to build the engine I'm not against spending some money on something like this to just make things different. I guess if I find this stuff I could buy enough to do one side and mock it up to see how it looks if it looks horrible..well atleast I only paid for one side
hipp11B
Apr 1, 2015
252
Georgia
Also thanks everyone for all the input!
Awenta
4,090
CT
You need to contact the manufacturers and check the fittings they can use. Also if the hose is fuel rated (some are some aren't) and make sure it's rated for a high enough temperature that it won't be compromised by under hood temperatures.
I can send you some websites of places that offer them later tonight if you want.
hipp11B
Apr 1, 2015
252
Georgia
Id appreciate that's sir! Thank you
07keo02
Oct 5, 2011
399
Phoenix, AZ
I thought about doing this for the possibility of lifting the upper valve covers up and out of the way and chaning injectors without removing the lower covers on an lb7.
hipp11B
Apr 1, 2015
252
Georgia
That would be cool
hipp11B
Apr 1, 2015
252
Georgia
I have thought about moving the lb7 return lines through the lower covers then external like lly+.A one piece lb7 vc would be a cool idea.
That would be pretty legit! Someone needs to do this!! I for one am going to contact some of these companies that make the flexible braided line that's 30,000psi+ capable and try this out on my LBZ. If it doesn't work they are at least getting powder coated along with the fuel rails and all of the remaining hard lines. I'm in the process of building a custom 4'x4'x6.5' powder coat oven!
Lbz, built trans, efi by Danville, Danville 68, full egr delete, mbrp down pipe, 5" mbrp to 7" stack, ppe guages, custom traction bars, airdog2 165, ppe fuel rail mods, s&b, afe blade runner, Arp head studs..died March 2015
Parts collected for the build. SoCal super damper, SoCal billet flex plate, SDP S400 kit, II 85% CP3, PPE manifolds/up pipes, PCV reroute. Slowly but surely lol
Awenta
4,090
CT
Sorry I couldn't get to it last night.
http://riverhawk.com/high-pressure-flexible-hose-assemblies/
They do water jetting but maybe they have other materials available.
http://www.gardnerdenverproducts.com/asset.ashx?id=3182
http://ph.parker.com/us/en/2640d-hose-series/2640d-025v32
http://www.norwesco.ab.ca/products/industrial-hydraulic-hose/ultra-high-pressure-hoses/
http://www.nlbcorp.com/shop/hose-couplings/ultra-high-pressure-2/
I'm sure there's more out there if you looked. These are just ones I've happened to look at. Let us know what you find out! I know industrial used to include a flex stainless steel line for the rail cross over. Don't know who makes it though.
Www.highpressure.com has alot of fittings and stuff if you need too.
hipp11B
Apr 1, 2015
252
Georgia
Thanks bud!
1,868
Ok, so you've found hose, and its going to be ex-pen-sive, but what are you going to do for fittings at the rail and the injector?
