In need of some wisdom.
Antiher03
Nov 10, 2013
165
Utah
All I can say is I need to practice launches. Ran 13.1 my last run with a 1.9x 60'
1,944
12.4 second run!
Do you even realize what it takes for a stock-turbo truck to run that? Its not as easy as you seem to think it is.
I red lit the last run seems like 10-12psi is the sweet spot I tried 15 and it just jumped all over the place
Congrats on the 12.86. 104 mph not too shabby. Try your best to get your 60-fts down, which will help your overall run.
It will take some experimenting like you did. Theres a balance between boost off the line, suspension prep and tires. You'll get her figured out.
BTW, what are you doing suspension-wise besides those bars?
1,944
His turbos not stock bud:thumb:
Then substitute "S366" into my post. It'll still read the same. Nothing "easy" about low 12s in these trucks, esp at full or close-to-full weight.
His elevation in UT will certainly play into it, too.
Antiher03
Nov 10, 2013
165
Utah
Just 2" drop shackles and cv's are slightly negative.
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
By No means am I saying it's easy. I was super suprised when I seen the board read 12.4. I didn't know he lit the red tho. And yes the elevation plays a HUGE roll here in Utah. I've even run a "LOOSE" converter with a stock blower. It seems to boost later and read about 5psi less then when I'm at or below sea level.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I'm not sure where you saw 12.4, his time slip shows different.
