it seems like alot of people get away with running extrude hone injectors with nothing else done i guess its just luck of the draw
Something! that's what pisses me off bout it
So you're gonna half ass it again and sell it to someone? That's pretty awesome. The answer to your problems is simple: buy injectors that have the same output
Yes a matched set is obviously the way to go. I ran extrude hone nozzles for 2 yrs 24k miles around 40 pulls and 40 strip passes with zero issues. I had one injector quite, and after the motor build money was tight so I bought a reman and put it in. Since then I have chased injectors around the motor. The new ones are always balancing good the old ones are the ones going off. What do balance rates tell if it isn't injector flow? Solenoid current would lead to flow so I assume balance rates equal flow. When I stuck a new one in the other injectors in that bank would show different rates. I assume the remans are cleaner and flow more efficiently and the old ones have to increase voltage and pw to keep up. Atleast that is the way it looks. If I can get my set rebuilt with bigger nozzles for 1500 let me know. I don't see remans with bigger nozzles for under 300 a piece and flow matched are more yet.
Care to retract that statement? Ask anyone who knows I wouldn't **** anyone over on selling it, it would get a fresh set of STOCK! injectors not modded ones kinda pisses me off you would just assume yes I didn't spell it out in my comment but I shouldn't have to I could sell this truck to some local kids it would be in good working order or to anyone for that matter.
If the mods want to close this be my guest it's going to get outta hand I feel
I just got my truck running an lost/have a stuck injector, injectors I have had ****ed luck with Injectors in the last 4-5 months! I'm so sick of this shit nobody has any ideas why? I've been way easier on the truck only run a 2200 pulse only 170-180mpa, 1 micron filters additives anything an everything I can think of! either Im selling the piece or Im going to try buying new ones I've replaced 5 one of them is at a +13.50 two old ones are -8.90 an -9.81 so all by two were +/- 4 but not sure how a stuck injector or two screws with balance rates on the rest. Sorry had to rant but this my shitty ass luck I'm tired of it so
Dont get mad, all I did was read your post.
Wow. Just wow. Lots of maturity here. No wonder i just try to figure things out myself and dont ask questions anymore, this is starting to look like a DP thread.
Ya no shit I gave up asking on a few other things so think I'm done asking on forums for the most part
I gave you your answer, and all I did was read your post which said you were either gonna sell the piece or put new injectors in it. Cant be pissed that you misspoke. Like I said how many people here have put together CR injectors? I explained why you cant just keep putting injectors one at a time with an extrude honed tip in and expect it to work. Why give up on asking when you get your answer?
It's not that it's the wrong answer, it's the jabs like "so you,re gonna half ass it and unload it on some poor soul"....that was uncalled for and you know it. Come on man, don't be ignorant, maybe make a suggestion instead of a snide remark like that.
By the way, just to make you feel better, I have extrude hone nozzles on used injectors all working fine. Saved myself a thousand dollars, and have no problems. More money thrown at the problem to have someone else do the work isn't the answer.
So he shoulda said he would be dissapointed to see him sell a broken truck to somebody who was assuming everything was kosher? Stuff like that ruins your reputation, fix it right and sell it right or tell the person whats up.
Lets look at this another way.
You want to rebuild your engine but you say its too much money for all of the parts so you dont buy the headgaskets or new bolts and reuse the old stuff, then your headgasket leaks a month later and you are complaining.
Thats they way I see this. if you cannot afford to do it properly you shouldnt do it, but if you choose to do it, dont get your panties in a bunch when it doesnt work.
so nozzles shouldnt be done thats all you guys are getting at? hmm ok i guess i shoulda said either ill get 45% over set that are flow matched or just put 8 stock injectors in an sell it. Happy now you guys?
Now as for jordans statment i never said your wrong but getting 8 totally flowed out an matched injectors and when i said im going with extrude nozzles nobody jumped in an said thats half assed your dumb blah blah. I started out with 8 injectors all from gm, the nozzles are/were matched to all flow 45% more call jim an talk to him. Started losing them after like 18k miles after the rebuild (which cause used lbz rods im dumb right?) an keep losing them but guess its my fualt i didnt spend the extra 1200+ bucks to get something from exergy or whoever did i take your advice right there? your snide ass remark is what pissed me off. I dont doubt injectors flow different with miles vs no miles so that means the older one fail faster? whatever i guess i will know better then to even ask bout nozzles here apperntly there a waste of money
Let me get this straight....
- You had 8 brand new bosch inj. from GM installed (under warranty if I understand)
- Then you did the engine rebuild with LBZ rods and at that time, had the 8 nozzles from the 8 new(ish) GM/Bosch inj sent to EH and opened up.
- Things were fine for 15K miles then you lost an inj.
- Bought a reman from II and put the nozzle in it from the defunct GM/Bosch injector.
- repeat the last two steps a couple times now?
I'm not aiming to speak for Jordan but I believe what he's trying to inform you of is that the problem comes from putting those extruded nozzles that from the GM injectors in your new/replacement reman injectors. It's not as simple as just swapping nozzles hap-hazardly from inj. body to inj. body. That's where some of the things Jordan is talking about comes into play. They need to be matched sets. Or at the least, each replacement inj. should have been sent to extrude hone to have IT'S nozzle extruded rather than put the extruded nozzle from the bad inj. unmatched in the replacement inj.
Obviously you know the best option but like a lot of things, there's a "Good", "Better" and a "Best" option to going about things. You haven't necessarily done wrong, just haven't done the best choices. Reasoning doesn't really matter, the choice was made and that's fine.
If I'm outta line, I apologize. Just trying to clarify what I'm getting from the conversation as I don't see the need for ill feelings and such. It's bad enough time to continue to have to tear into your truck, muchless have to try and bicker about nuances when all you really need is a new plan of attack, a lil support and perhaps some better guidance or at least more knowledge to help you better pick what you wanna do.
There's been plenty of good info. passed out so you should be able to move forward now.
Good luck and sorry you're luck hasn't been so great.
