You should be able to connect to the quick connect on the drivers side of the housing and it should bypass the housing. I've read that's how you do it, but have not done it myself so maybe someone else can chime in and confirm. As far as bleeding the air off i believe it will bleed the system when you prime the lift pump.No I cannot. I have the airdog running through the filter housing. Can I bypass the housing itself and bleed the air somehow?
