Ive already got the headers lined out, a big block header with d port tubes. the bore spacing is close enough to be able to tweek the header tubes and weld them to a set of dmax 3/8" steel exhaust flanges.
when I bring in torque can be adjusted for lively hood of the engine. correct me if im wrong but don't the highest percentage of broken cranks happen due to an unkeyed crank.
I'm still trying to grab the concept of the English language
Did you cut your firewall to get the engine to fit
Your build with a bone stock motor and EFILIVE tuning will be a blast to drive. Stock turbo will spool instantly and blow your tires off at any speed. 3800lbs and a stock tuned motor will run 10.9 all day long foot braking it. Keep it simple and have lots of fun with it. You can always upgrade or change it up down the road.
Hell a built 400 and 2.5 gears would be the best budget minded build and would work great for the street. Would not miss a beat and still be a blast to drive. I ran that combo for over 20k miles and would do it again in a heart beat.
No, not necessary for stock turbo.
How was fit around the front cross member
Ballpark... What'd you have into your car with the duramax swap. Engine trans & chassis?
