I hate my trans
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
I loaded the stock tune back into the ECM and the TCM, it was still doing it, then it stopped and I did a WOT run and it was fine, then it started doing it again!:mad:
I am at my wits end!! Still no Codes!!:mad:
beach_33
704
des moines, IA
did you actually look to see if there where any codes or are you just going off the check engine light. i would actually look to see if there are codes because for some reason my check engine light would not come on but i had codes
gtmax
Apr 9, 2008
54
suncoast built it, i replaced the VB about 8 months ago
Why did you have to replace the valve body? What was going on before the VB change, any codes then?
Strange that it worked good, then bad, makes me think it's not an internal trans problem. The thing should code.
15,681
235
I agree.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
it was doing the same type of thing.... it was coding up a storm back then, all sorts of low voltage codes, etc. but this time nothing.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
with my stock tune at WOT it shifts perfect sometimes, also with little to no throttle it shifts perfect. but right in-between it flares the shift soo bad.
I loaded an old tune today, ran it, when the 2-3 shift came up i didnt let off and as soon as it shifted into 3rd after the flared shift and BANG, it lit the tires up and the truck went sideways, the downshifts are getting ALOT worse too, I stopped at a red light, fairly quickly and literally about 2 seconds later the the truck jumped forward, if I hadnt had my foot on the brake as hard as i did the truck would have been in the middle of the intersection.:mad: WTF is going on! Still no codes!!
15,681
235
I would pull the trans out and take a look. Sounds mechanical.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
well thats chitty, I can afford that right now, think it will hurt it to drive it like this for awhile, as long as i let off before the 2-3 shift?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i think you are asking to break some hardparts. that bang is a tie up i would park it or it will get more costly if something breaks .
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
I have a new internal filter laying around, does anyone think it would do me any good to drop the pan and replace it with some new fluid? It really seems like the trans isnt getting enough fluid fast enough, then when it does get it it shifts fine.
