i found my screw driver
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
The bend was probably too steep for the screwdriver to actually get into the blades as that would have resulted in immediate, very noticible, catastrophic failure.
9,905
151
That's better than Pat's rag he left in the intake!!:rofl:
turbostang7
Apr 11, 2011
239
Rexburg Id.
wow! thats crazy! i have seen some bad stuff at times, including a roll of shop rags in an oil pan, several rags stuffed into intakes, a few wrenches here and there. but this one is bad!
come to think of it finding all that i have is kinda wierd too, aparently people don't take too much care when working on equipment out in the field haha.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
my avatar:eek: had to change my sig too:eek:
so damn lucky it didnt destroy the wheel and had the crap go into the motor:eek:
and for the record thats probably the only reason you won james.....had i not had that restriction in the intake.....:rofl:
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Oh it will be. ill be royally pissed if it aint. course it would be my fault :D. It will probably be my first run with it down the track too unless i gotta show brian up first :woott:
James dont forget to install a high performance screwdriver in the turbo :rofl:
J/k Joe ;)
6,081
:roflmao: what ever makes you sleep better at night. i still won :D :hug:
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Okay I'll ask... How could you have zero boost, if the screw driver never hit anything you have another reason why it wouldn't. It would have to be a huge leak to get 0 psi, like a torn ic boot. You didn't find anything else on inspection? I agree the horn bend must have saved it from working its way in... I suggest you remove the boot on the turbo/ic and pressure test it from there on.
Sent from my PC36100 using Tapatalk
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
here is what i think happened, that screwdriver was loitering at the mouth of the turbo all this time, unntil 2 weeks ago it finally gathered enough courage to go into the turbo....dont even ask me how or why the turbo didnt blowup because i have NO FRIGGIN CLUE...prob. because lbz's are just too tough to die.:D
so when the screw driver went in it jammed up the turbo, thus giving me the 0 boost symptoms.after i removed the screwdriver from the turbo it went back to being an lly eatin som' bitch:D
i finally drove it today for a good distance and seems fine:woott:
6,081
im glad you understand you cant beat the lb7s :D
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
He's just pissed this lly eats his lbz up here at lvms. :D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
It's a good idea to keep a few tools in your truck.
Not a good idea to keep a few tools in your engine.
This has been Public Service Announcement from the Turbo Rebuilder Assoc.
