Did you examine the FPV for any cracks? Also in post #36 I was wondering if you had done a bottle test for the return rate. I also hope you cp3 isn't getting a lot of "blow by" which wont allow it to compress the fuel as much (sort of like when a piston ring gets a lot of blow by from wear). The cp3 pistons don't have any rings, so when they get worn enough,,,,,,One other thing to wonder about is if there are any soft lines before you lift pump that could be collapsing some during a high fuel consumption rates. If there is any soft lines before the pump, make sure there not to soft.
