i dont know what to do here fuel problems
mch646
Dec 13, 2011
54
utah
OK and I'm going to shim the fprv tonight and do u k ow what thread size the bolts on the Turbo intake horn are I droped one last time and found it but would be nice to have extras around
mch646
Dec 13, 2011
54
utah
ok just went out turned the truck on not running and unplug and plug it back in when power goes to it i can hear a humming sound.
super diesel
<<<< Under Pressure
The bolt should be a M6x1. Measure its length (if you don't have a metric scale just measure the threads in standard and multiply it by 25.4 to get the metric length) in mm. The cap inside the FPRV is a 6mm metric hex IIRC to get to the spring and needle valve. Once you pull it all apart, carefully inspect the end of the needle valve for cracks too (with a magnifying glass if you have one). When you re-install the turbo horn, put the bottom bolt in the horn with some grease or something to hold it in place. I always take the alt. and put it off to the passenger side and lift up on the wiring harness (carefully), and thread a 3/8" 10mm socket on a universal joint with 2 6" extensions under everything back to this bolt to loosen OR tighten it. I always remove it with or return it with the horn.
mch646
Dec 13, 2011
54
utah
i am really hope that the fprv is the problem ha and what about tigging the end of the banjo bolt shut? heard of that as well. and looking online i heard m4 washers fit perfect so ill grab a couple of those. but how many 1 2 3 4 lol
mch646
Dec 13, 2011
54
utah
Ok I shimmed the fprv and still the same symptoms talking to gillette diesel and dimitri I was told to do a injector return rate test because one bad injector can drop duel fuelers i guess and supposedly there is a sensor for the fuel pressure regulator in the cp3 that could be bad too I was told
super diesel
<<<< Under Pressure
Did you examine the FPV for any cracks? Also in post #36 I was wondering if you had done a bottle test for the return rate. I also hope you cp3 isn't getting a lot of "blow by" which wont allow it to compress the fuel as much (sort of like when a piston ring gets a lot of blow by from wear). The cp3 pistons don't have any rings, so when they get worn enough,,,,,,One other thing to wonder about is if there are any soft lines before you lift pump that could be collapsing some during a high fuel consumption rates. If there is any soft lines before the pump, make sure there not to soft.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
No bottle test yet which return line do ya want me to hook in to
On the Lb7's you have to make test lines to do a proper return rate test , basically you have to isolate the returns from each cylinder head into 2 beakers , pull the main injection fuse and crank the truck over for 10 secs and measure the amount of fuel returned , the spec is no more than 20 ML , but normal is around 12-15 ML.
dwax
Jul 21, 2009
127
I had almost the exact same symptoms on my LMM. There is a small check ball on the LMM fuel filter assy that opens when you screw on the filter. It was gummed up and somehow had trash in it. I cleaned it and put a new filter on and it ran perfect. I know you have an LB7 and im not sure if you have ruled out the filter but may be worth a check.
mch646
Dec 13, 2011
54
utah
Alright I will look for the return lines and run the return rate test. Then I don't know if it would he that check ball buy I will look into it.
mch646
Dec 13, 2011
54
utah
Hey Trent where are the return lines for each cylinder head? And another thing all my tunes have a large us for easy starting while cranking could this mess with the return rates
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
DS in on the back of the head.......PS is on the front
PS you will have to some how tie into the line further down from the head.
i dont remember if there is a hose or its all hard line on a stock truck? but its tough to get at the head as it is behind the alt bracket.
super diesel
<<<< Under Pressure
Bingo. You can cut the return lines at the banjo bolt which are at the junction block where you got into the FPV and then reconnect them with fuel hose when your done. Makes testing latter if needed easier too. Maybe this is way off according to others ideas but this is the way I do it. Your results may vary.
mch646
Dec 13, 2011
54
utah
Since they are low pressure returns I'm gonna cut them put a t fitting in and just plug them when not running a return test
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Michael
I Its been so long since ive seen the stock lines:)
Testing is easy with this fuel block:D
attachment.php
