I have a humming noise sounds like it's from my pass side front. Thought it was tires have swapped them around no real change. I changed the hub on that side even tho it no play that didn't fix it ether. You can mostly hear it at 45 up to 60 besides that it's fairly quiet. My stub shafts have some in and out play but no up and down play really and it's not any worse in 4wd. I'm really starting to be at lost of what it is any help is appreciated. I was able to put a quart of gear oil in the front diff the pass side seal leaks a little but that hasn't really seemed to help ether. Both my cv axles are only a couple months old changed them for tore boots
