Huh? LMM Turbo Shaft Question.....
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
Is this chunk missing out of my turbo shaft normal?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
Both ends are balanced. That metal on the hub is put there so it can machined off for balancing the compressor wheel. Compressor wheels are balanced individually so you can swap them.
The turbine shaft is also balanced. Look at the other end.
Alligator
Nov 9, 2006
1,919
N. Idaho
Oil is normal. Pull off a lower intercooler boot and be prepared for a shock. :D
X2, I had a bunch of oil in my intercooler tubes and turbo after cracking my piston... It shit so much oil it made my truck smoke white for the first day of my new motor running.
slowlmm
Mar 2, 2008
2,582
46
so cal
his oil i bet is from the pcv not rerouted but yea i had a bunch oil like you chad I am willing to bet no craked pistons in his motor
slowlmm
Mar 2, 2008
2,582
46
so cal
Even in a healthy stock truck, oil in the intercooler tubes and charger is normal on LLY/LBZ/LMM's.
even if the pcv is rerouted ? I know when its not its gets a bunch of oil mine had a bunch as well untill i rerouted it
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
No, if you don't have PCV going into the intake, the only oil you'll see is if you have a gauge/oil filter (K&N Style), and it will be very light.
The PCV makes a lot of oil even in a 100% stock truck.
