LB7: How much HP?
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
You can drop the tank or pop the bed off. I will pull the bed off as I have a hoist in the shop. I would much rather go with a sump in my tank then to put the draw straw in. The Air Dog II does not need a draw straw if I remember correctly
maxaholic
1,876
40
Central, Texas
Fwiw my A.D. is hooked up to the factory pickup and I see 11 psi on my gauge. But my gauge is temporarily hooked to the pump. I need to move it up to the filter housing and get a better idea of the pressur there. And then if need be I'll put in a sump or draw straw.
1,866
So more like 260-270 at the wheels stock..?
240-250 is more common. Id go with an S&B intake. Reasonably priced, draws air from underneath, too.
If you want 500rwhp, dump the Hypertech and go buy EFILive from one of the vendors here, and have them set you up with a DSP 5 switch/tunes. Then you can have the stock tune, tow tune and 500hp racetune.
Who's building your trans to handle the 500rwhp?
02bigstrokin
Sep 9, 2008
882
might want to check that. we just installed my drawstraw last week, and at over 1/4 tank it was spitting ans sputtering and pumping a lot of foam in the bucket. after install a solid full line of fuel:D
maxaholic
1,876
40
Central, Texas
Mine has been fine. But since I don't use my PU for work anymore I think I'm gonna put a sump in.
jrkrace
269
Connecticut
Slightly off topic, but does anyone know what a stock LBZ will put out for numbers?
I had mine on a dyno with Trippins tow tune and nothing else besides a Banks cat back exhaust and the truck put down 343hp and 601 tq pretty consistantly with a spike of 351 hp and 641 tq.
Just trying to see the difference with the little mods I had.
Pure Diesel
893
150
Ventura County
My 03' with just a K&N drop in and exhaust did 240.67 HP & 404.28 TQ
Same truck with just the Hyper Tech added, did 318.04 HP & 506.11 TQ.
This was done on Dynojet.
I wasn't very impressed with the Hyper. Its a clean safe tuner.
Go with the EFI or PPE and a tranny from Mike.
Duracopter
<-LBZ Project
Oct 29, 2009
50
Little Rock, AR
I know mine is a lly with 310HP stock and it did 268 stock then 407HP on level six on the Quad and Pats right it don't like the 5-4 or 4-5 shifts at all!
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
lol. beat it hard enough, it'll eventually hate the 1-2, 2-3 and 3-4 shifts as well. That 135 tune killed my last trans.... :D ....as did the 160, 190 and 215....
DJack
Nov 24, 2009
Houston TX.
Nice thread... So is it safe to say most trucks like ours loose around 50-60 hp from the fly wheel to the rear Tires ?
