Wow. How'd the transmission feel about that?
251* certainly isn't good, I'd be flushing it.
250(121c) is consider "hot" 255 (124c) is very hot and ecm derates fuel then limps
Definitely flush coolant and oil change
Along with differentials and tranny case better they where pretty warm as well
122 deg. Celsius? How long did you stay at that temp?
I would not be worried about a temp spike to 251F if it was just a spike. How long did it stay at those temps? Did the DIC tell you you were overheating?
Trans only got to 109 if I remember. Will check the records on my cts. Just a quick question how much coolant does it take wondering if I have enough on hand.
Unless you burned off some coolant, you didn't hurt that in the least. Check the mix, if still OK, don't worry.
What you need to worry about is all the other things that took a beating getting that hot. None of the gaskets on the engine like those temps and the oil usually takes a beating.
First thing is to change the oil. Run it for a while, then get the replacement oil analyzed. See if the oil broke down to the point of damaging any of the hard parts.
Gasket wise, the head gaskets are the most susceptible to failure from overheating.
I drag a 20,000 trailer over hill and dale here in Pittsburgh and have gotten hot many, many times.
I have no idea were to get oil analyzed.
