Hole saw for stack...
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
I'm having trouble locating a big enough hole saw to put my stack in. I want to do a 6" stack and have all the clamps etc underneath the bed so I was looking for a 6.5" hole saw. Where are you guys getting yours from? Or how are you cutting your bed?
Sent from my EVO
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Mine was reduced down to 5" and I just made a 5" hole. Just buy a 6" and then file around the outside a little bit and that will be fine. I did cut my 7" hole in my hood with a jig saw, that was fun.
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
Hahahaha I hope I'm not cutting my hood soon lol. Maybe I'll just use a jig saw and make or get a beauty ring like that you used on your hood stack?
Sent from my EVO
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
ill look for the company that made the one I used. I used a 6" saw, and used a 5" reducer which brought my stack tip up to the top of the cab, that way the stack wouldnt be sitting up against the bed and possibly causing vibrations/bad harmonics. to mount it, I made a ring that I welded around the base and bolts to the bed floor for a clean look.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
39
Your running 6" exhaust through your bed? I have a 5" holesaw you can use if your running 4" through the bed.
bartman432
Nov 4, 2011
242
FYI, if your bed is line-x'd, I found it impossible to use a hole saw. I had to drill a starter hole and use a sawzall to cut the hole.........what a bitch that was.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Milwaukee makes 6" hole saws but we cut ours out with a 4 1/2" angle grinder and it looks good. We also cut a trim ring out of a sheet of aluminum the same way and polished it up.:D
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
i used a torch lol i didnt care cause i put the alum heat shield in the bed to cover the pipes so it didnt matter to me
custom8726
2,784
Upstate N.Y
I used a hole saw (Through my Line-X) with out issue and it came out very clean IMO.. I bought a complete set from Lowes but I think they only go to 5" IIRC... The nice thing about using a hole saw is you can easily Mig the cut back in if you have a change of heart at some point and dont want to leave a ugly hole in your bed ;) Heres a pic of mine,, You are welcome to borrow one of my hole saw bit's if I have one big enough?
