Hit lockup switch lock button, loud bang, P0776, strange noise....
I was testing a new BT lockup switch in my LLY that I got from Ben this afternoon to make sure everything was working correctly.
Left a parking lot, got on it probably 50-60% throttle, hit the Lock button when I was going probably 45-50 mph, and BANG....loudest and harshest shift (I'm assuming shift, I doubt a converter could lock that hard, unless I got a combination shift and converter lock at the same time) I have ever felt. Trans felt like it went to neutral (engine would free-rev), CEL popped on (P0776), DIC showed Range Shift Inhibited. I was able to pull over, shut the truck off, clear codes and drive, but when it tried to shift either to 3 or 4 (not sure which), felt like it went into neutral again and CEL popped on again, same P0776 code.
This all happened about a mile from my house so I limped home. Put it into R to back into the garage, it hesitated for a second then kind of shuddered into gear and I was able to back up. Put it in P in the garage, opened the door to listen, and there's a kind of mixed growling/scraping sound coming from underneath at idle.
How bad is this thing F'ed up? I'm assuming I toasted a clutch pack or two at a minimum based on what I've read, but I also saw an older thread that talked about losing a planet and hub as well.
Also, most importantly, how the hell does locking the converter manually cause this? What did I do wrong, and what should I know better for next time?
Mike, I'll be calling you in the morning to set up some time to come see you again, just would like to get an idea what the hell happened.
