Highest Dmax hp?
Dave c
Jul 7, 2013
294
Just out of curiosity, anyone have an estimate of what Buck and Jesse's truck would put down or Rob Coddens? Those are two really good preforming trucks, far as I know neither of them dyno.
Buck and Jess are some really cool guys, No doubt they make lots of power. I love there truck.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I think I saw a post recently of Max'd Out rolling a few 1100's then something like 1460 on a break in run.
Has more on tap for sure :D :thumb:
Dirtymaxx03
3,109
I think Rob is the only one that knows how much power that truck will make when pushed to the limit.
Subman
Old Geezer
Jun 27, 2008
3,233
10
80
Madras, OR, Pahrump NV
Talked to Rob a couple days ago and they had Max'd Out on the dyno trying to figure out why it was stacking shifts. Said it laid down a a little over 1400 and they weren't really dynoing it for hp #'s just working on the tranny. That was fuel only. He'd got Dustin's injectors in it as well due to a problem with one of the other injectors spitting out the little ball bearing that in on the side of the injector. I'd say it makes close to 1500 on the big tune.
I don't know how much Bucks' truck makes, I'm sure it as least what Max'd Out will make and probably a little more.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Comparing dyno numbers is retarded. No one ever puts corrected or uncorrected, load cell or not, mustang or dynojet. Yet alone non of them are going to read the same. That's why track numbers tell a true number to compare.
cafryer
May 5, 2011
1,074
Utah
Perfectly said
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
39
Windsor, Ont, Canada
Also I remember Rob saying he has no need to make huge numbers ha has nothing to prove he only pushes the truck as hard/fast as he needs to win.
Its true if you can win on 1500hp and not break stuff why would you go for 2k hp and most likely break stuff or more stuff.
durallymax
Apr 26, 2008
2,756
Under The Hood
But some people don't know how to drive on a track, or they count butterflies on the line (bri):rofl:
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
A Dyno is a tool like a box end wrench . You get a base line HP number or torque you make a modification you re-run the Dyno you get your net HP or Torque increase.
Getting a peak number is nothing like Subby says, but bragging rights. If it cannot be sustained at the track what good is it other then conversation?
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
X2 Brett's truck hasn't ran faster than a high 11 second 1/4 mile iirc
