HID's messed with my truck. now no DS lights
Dozerboy
4,926
508
TX of course
You don't need voltage sensing relay for the older trucks only the LMMs. There easy to build yourself, but the premade harnesses are cheap though if you don't do much wiring.
Ebay
Thor200587
Mar 17, 2009
Sounds like a bad ground to me as well. When I first wired up mine I had the same problem I re-wired them and they work fine now. I did burn out 2 bulbs because of the ballast not getting enough power. Just go to your local auto parts store and pick up a relay and some connectors. Then google "HID relay wiring diagram" and you can find several images to help. Relays are so cheap and easy I use them as much as possible. I loathe electrical issues so to me it's worth it. Good Luck!
coderighter
Mar 13, 2013
Seattle
Ebay
Sorry, new here, but I was wanting to build voltage sensing relay for my HIDs and was wondering how you do it? Thanks
