haha, well hello.. and im not taken.. not yet at least...
What kind of tech post is that.......:stirthepot: :drool:
yes, im leaving it bone stock.. nothing performance wise going on here...
Do people still do that with a duramax
hahahahha! people who dont have a high income, yes! lmao the motor is stock...
I picked my truck up yesterday and its making Loud clattering noise kinda sounds like the valves, it does it when i give it gas and also at high RPM's any ideas would be appreciated....
:1bird::gay:Welcome, LLY's are the best engine year
this is an intro thread chris please keep tech to a minimum, or i may have to push my completely imaginary ban button:rofl:
Chris does not ban people, he sends them on short term "un-paid leave"
Hey, Kayla, from your description, it could be loose valvetrain but it also kinda sounds like combution/injector rattle.
Did you get a whole diff motor or have your old one repaired? If its been repaired, it could be a valvetrain issue.
If its a whole nother motor, might check it for fuel leaks, restricted lines, and such. Id recomend replacing the fuel filter too. If it has had a new filter put on, I've had some issues with some filters causing rattling too. If its drawing in air to the fuel system or if theres a restriction, it can cause that loose valves sound.
I also would inspect, the flexplate/flywheel bolts, crank damper. Theres actually a number of things that could be suspect. Especially since you've just had a major repair done.
Like Trent said, would be a very good idea to start a fresh thread about your problem and with as much info as you can provide so we can help ya better
thats the truth
well thanks for all your help, ill head over there now and post a thread
