any updates on EFI launching tuning for the transmission for the LML's?
Mark
Same info I've gotten.It's been done. I believe tuners are waiting on a way to lock the tunes.
What do you think about the new shift kits for them?
I see the name is a line pressure upgrade kit then. Is it worth doing without doing a full build for a tuned deleted daily driver?
So you at minimum should replace the convertor if you do this?Trans has to come out for this mod. Pump has to be dis-assembled. Converter clutch may not like the higher pressure as it can break the lining off.
Ben's pressure mod works well instead as it is all electronic.
