LB7: ***help***
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Okay, here's some scan tool readings- Main Fuel (MM3)=79.7 - Des FRP (MPa)=45 - Act FRP (MPa)=5 - Des FRP Reg (mA) =794 - FPR Reg CMD (mA) = 778. other than injectors redone only thing changed fuel wise was a piece of hose that comes off filter base, brand of fuel filter (AFE), and bleeder screw repaired with no sign of leaking. I've bled it filter and test port at right front. Just cant figure this out.:confused:
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
yes, I pump til it gets hard. softens up quick when I crank. If I crank a bit then let fuel come from test port to a cup, its a little foamy at first. What I'm thinking of doing is disconnecting both lines at left valve cover, cap off return and applying air pressure to supply. I cant see if pressure holds or not. if not start spraying around with soapy water. I just hope its not a return under valve cover.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Chris sorry I didnt call you back, I was really busy today with a buncha stuff...are you going to be around working on it tomorrow?
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
well, this sucks! oil's gettin' thin! Is there any easy way to isolate a side to test for leakage? I was thinking maybe remove return from corner of head and pinching off supply hose and checking for vacume there. or does vacume pull open injector and I'm pissing in the wind?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Injectors are opened electronically. Most people will run a dye in the fuel system and then remove the valve covers and look for the leaks with a black light.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
well, Duratothemax is commin', Tinman22 might be there, so its either a mtg of the minds or stooge fest. :thumb:
tinman22
715
Stillwater NJ
nuck nuck nuck. yea I might be there. havent heard from the boss so i'm guessing work isnt happening. i'll try to confirm that asap... whats meeting time tomorrow?
