LB7: ***help***
tinman22
715
Stillwater NJ
i'll try and get to the shop in the mid AM maybe closer to 11 since traffic sucks between 8 and 10 for me to get there. and hopefully you will be able to get it back on the road.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
It would give a code also. Snap-On scanner said no codes present. Its gotta be fuel. I just dont wanna burn starter out. hoping for some insight.
Fingers
Village Idiot
1,719
104
White Oak, PA
Three things to check:
Injector return lines. (not the one from the pump) Is there fuel flow? Fuel = Good
Pop the glow plugs. With the injector fuse pulled, crank. No Fuel puffs out of the holes? Good. Fuel puffs? Hung injector draining the rail.
With the glow plugs still out. Put the fuse back in. Crank. Puffs out of the GP holes? Good. Injectors are firing. No? Find out why the ECM is not commanding the pulses.
Even if you don't get return from the injectors, popping the glow plugs makes it crank a lot easier to prime the system.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Well, I went to replace bleeder and threads came out with it. so, I guess it's a bad idea to cut down a bolt as a replacement.
tinman22
715
Stillwater NJ
yes that is definately a bad idea. I have some logs.. there is a fuel pressure problem.. most definately from sucking air through the bleeder screw. heres some logs
  • logged files.zip
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I have stock filter head i was going to post up for sale , not shure how fast you need it or if you could get one closer ?
tinman22
715
Stillwater NJ
now thats what I like about this place. always someone around to back up a man when they are down. that may work as a plan B if plan A goes down the tubes.:thumb:
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
so I fixed bleeder, also line going to #1 injector was weeping up between line and nut. After line repair, it made an attempt to start twice. now just cranks again.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
apparently there's no pulse. spun with finger in front of hole, and dry.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
40lbs o.p. Well I checked for signal with a vantage meter and theres only a quick intermitten 15v, which would explain random fire. now I guess its an electrical problem. any hints what to look for?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Since its new do you have good oil pressure?
I may be way off , I am still learning but didn't I read somewhere about low oil pressure no start? Also we have had some antitheft problems with no codes setting also.
they will start with no oil pressure
if its an anti-theft problem it will start for a split second then die. Also, the security light would be on and the tech 2 would say "VTD fuel disable - yes" under the 'engine data 2' screen.
ben
