Help Turbo shipping damage.
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
Call Brayden have him overnight a new one to you and then have him contact the shipping company... they will reimburse him no problem
Overnight to Canada is not feasable. It would be over 500.00 and they won't cover the cost of the second turbo shipping.. Just the first.
That's the second turbo to canada that was damaged in two weeks.
Brayden
Jan 16, 2008
1,170
No way in hell would I put that turbo on...you paid for a brand new turbo, I would expect nothing less. Those turbos should be sent in a hard case not a card board box... IMO
Thanks for the advice.. I'll get right on custom tooling an injection molded case.. It's only about 10,000 ;)
They're packed well, you just can't keep some idiot from dropping it.
Brayden
Jan 16, 2008
1,170
I wouldnt mount it. by doing so you accepted any risk to any damage that could accur. Put in a box, ins for $2000 and send it back. and let them work out any details. thats part of being a businessman, sometimes you have to eat a little!
If he wants to file a claim with UPS he can. They're insured.
The reciever has to file a claim. I can't do anything.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
The idiots at the shipping places just throw the heavy box's. My brother inlaw works at one of them and they brag about doing it.
2,097
This is incorrect. The shipper has to initiate the claim with UPS, Brayden. Hopefully Dave saved all the packing materials, as I think the local UPS center will want to see the them. Not sure if him installing the turbo will affect anything....it might, though.
Also, instead of a blow molded case, setup...why not look into something like these products to help: http://www.sealedair.com/products/protective/instapak/instapak.html Heavy box like that will be a base in trailers/trucks, etc....keep that in mind. Sorry.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I do have all the packaging but for what it is I'm not sure if it's worth the headache. I learned along time ago not to get rid of packaging until everything is assembled.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Heres a trick...For shippers. Not telling Brayden to do this just came up so I'll share...
Put garbage bag in box with top opened. fill with foaming insulation from home depot about half way up. twist bag up good so it doesnt leak. After foam starts to get hard lower part (that is wrapped in a bag itself) into box and hold it as foam dries....(thats the tricky part). After the foam is holding part by its own weight, fill box with rest of spray foam, not too much as it expands, just enough to fill box (you can also line box with additional bag in the begining to hep contain the foam at final stage). Spray until its topped off. Close lid and tape closed.
Yes, No? Discuss
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Overnight to Canada is code for 2 weeks
Bloody Canadians:D
Suncoast does that and they where more mad at me for not sending there coffin back to them ,actually charged me for it.
However you want to.. It think if it's on the truck already I'd leave it. We'll send you whatever you need though to fix it down the road.
Good luck Sunday.
Brayden
Thats sounds fair
After all the work i would run it too:D Ive ran with bent pipes before I just hope it stays on for you.
2,097
Yes, No? Discuss
My link is the same thing. But I didnt think about using the cans of foam insulation. :rofl: I always tell my customers to pack their items like they're going to go thru a war. You never know whats going to happen over 1000s of miles of travel thru who-knows-how-many stops.
Shipping to Canada is a PITA, thats for sure....and it always seems that problems happen when dealing with customs.
Dave, I hope it all works out for you.
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
I would be careful trying to bend back cast....even if it doesn't crack it will be very fragile and stressed and could crack if you over tighten the clamp. I'm not a turbo shop but I would think the cover is done in a cnc lathe and they all should be the same.
I wouldn't bend it back.
Brayden would have to confirm this but I would guess this is custom cover territory ;)
Brayden has been great to work with if anything goes wrong he'll take care of you :D
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I tried to straighten it, it's tougher then you think. When I started looking at the BFH I thought it was better to just leave it alone. :D Good news is my headers and up pipes came in about an hour ago.
