HELP! oil pressure low! gauge dropped to nothing!
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Nothing looks out of the ordinary with the bale connectors.
Got efi plugged in ready to go...
In case I get distracted, Just want to say thanks to everyone for the help too!
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I'm hoping for bad sensor...
Left MI last night, down to NC, everything was perfect...
Gauge is staying at 0, but engine sounds fine
cdbright
JUST RENT IT
Dec 16, 2008
1,015
Salt Lake City, UT
i had a oil pressure seding unit that had a slight crack in it, and would send speratic signals when it felt like it, esp rollen down the road, confused the hell outa the computer
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
not for nuttin, but don't some of the clusters have issues w/ the oil pressure gauge going dead?
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
any way to test the sensor or gauge?
when the thing dropped to nothing, I pulled off instantly. But I said, I'm going to get run over here, enginge sounds normal, no noises. I drove it a mile or so to get to a safe spot. It sounded fine. But I hate to run another couple hundred miles based on my guess of sounds fine
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
no, the stepper motors themselves can go bad. The cluster gets the oil pressure reading over the data bus from the ECM. Then it sends the signal to the stepper motor. If the stepper motor goes bad the needle can show zero. BUT this would NOT trigger the "LOW OIL PRESSURE" warning in the DIC and dinging, because the cluster is still getting a "normal" oil pressure data signal.
Make sense?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
can't the guage be grounded to see it will peg out?
no because the cluster gets all its gauge info over the data bus and translates/decodes that into coolant, battery, trans temp, oil press gauge/needle readings. Its not like the olden days when each gauge was wired to a sensor.
