Did the whole thing rebuilt co3 injectors film and relief valve idols fine if you reve it it wines then driving it any throttle at all smokes really bad at first thought it was the turbo but it's not stuck or locked up so am at a loss as to where to go from here
Co3?
Injector film?
Idols fine
DaFuk?
Lol
OK, well like the other members have already said...
Sure Sounds like a Boost leak
Or maybe the MAF didn't get hooked up or got unplugged somehow
But the "whine" you said you heard sounds like there is probably pressure escaping from somewhere and the discription you gave of it "idle's" fine but smokes alot under laod typically means the engine is getting fuel and no/not enough air into the cylinders
I've had a rag blocking the charge air path before, I don't think that's what you got going on
Check all your connections/boots...make sure the boots are fully seated and square to the piping and make sure all the clamps are all TIGHT...
Check the Y-bridge over really well, not sure if it's a 2 piece unit on an LB7, but if so they can be problematic
Good luck
