Head Studs
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Thats what i figured that most were using the screw in cups since we all know of the failers of the welded cups. I pulled my driver side cups and resealed them. I think my problem lies in the other bank since they were never resealed.
quadracer37
Mar 31, 2009
547
northern, IL
I had no pushed cup issues with stock hold downs 100+ psi, for 18k miles. Pull truck has billet hold downs and no issues there. Seems like a hit or miss with people pushing cups
S Phinney
4,008
Quncy, Fl
I will update my findings now since I took it apart today. There was no lifted heads. There was plenty of water in number 3&5 cylinders. I had that head pressure tested and it has cracks in both of those intakes. Tomorrow I will have the drivers side and another set of heads pressure tested to see where I am at on things. It really sucks to be having these issues for so long now.
S Phinney
4,008
Quncy, Fl
It is one of Tony's GM pumps for turning higher rpm. Looks like a modded new style pump.
S Phinney
4,008
Quncy, Fl
I didn't think that the electric was best for my overall plans. I have spent a small fortune on this thing already.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Depends on your luck I guess. My brother ran 80 psi on his 03 with stock head bolts. It never blew a head gasket in 6 months of abuse.
Then it chucked a rod through the block. :roflmao:
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,543
527
Central OH
To those who have HG problems, are you setting the studs / torquing them correctly? Finish quality on the head has a lot to do with sealing ability too.
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
I have A1 studs. I dont make the same kind of boost you guys do as my motor is tuned to preserve the gummy rods. I have about 20k miles on the studs, 180k miles total and still on original gaskets!:thumb:
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I'm not saying it doesn't work for some people. It's a gamble some are willing to take. It's almost as good as reusing headgaskets. It would probably work in a couple trucks, but are you willing to try it unless its the last possible resort?
